No speedo or tach
Old Nov 14, 2015 | 10:44 AM
Bushrat's Avatar
Default No speedo or tach
I have a 2000 Silverado and I have lost the speedo, tach and the transmission indicator light, not sure what else. Anyone have an idea , can't seem to find a fuse for that.
Any help would be appricated. I am a long way from anyone who can fix this for me.
Old Nov 14, 2015 | 4:54 PM
2000 new body style or 2000 old body style?
are the gauge needles resting on the lower stop or stuck in any random position.
What is a transmission indicator light?
the fuses should be labelled in the owners manual. The cluster fuse is probably labelled IPC fuse.
Old Nov 15, 2015 | 10:18 AM
Bushrat's Avatar
Default New style
The gauges work find no lights except check engine light. The transmission light I referred to are the Park Drive and reverse indicators.
I am now having the problem of the engine stopping at random intervals. I mess with the relay and it will restart but may not keep running. I have replaced the fuel pump many times but in the passed it howles before it quits. I am in the jungle in southern Mexico and can't get it runing well enough to make the three hour trip to town.
any help would be great
Old Nov 15, 2015 | 5:43 PM
You need a new cluster. There is one good thread on this site about repairing the cluster. I will try to locate it if you want to attempt this.
Post the doc that is set in reference to the other problem.
