NTD or IFS suspension lift
Old Jun 7, 2012 | 6:14 PM
chevy619's Avatar
Default NTD or IFS suspension lift
I see that rough country now carries a non torsion drop 6" suspension lift while a lot of others are IFS. What's the difference? Is one better than the other? Which would you recommend for an 01 silverado?
Old Jun 7, 2012 | 6:20 PM
country_09's Avatar
NTD is the type of lift and IFS is what they lift goes on. NTD means the truck is lifted, but the t-bars stay in the stock position for a cleaner look with more ground clearance instead of like all full drop and some knuckle lifts where the t-bars are brought down along with all the other suspension components. IFS means independent front suspension, meanin a non straight axle truck.
Old Jun 8, 2012 | 4:41 AM
johntaps's Avatar
Former Sponsor
In case of Non-torsion bar drop kits there is no need to drill holes into the center of your frame to bolt on the brackets to extend the torsion bars. Both are good and almost same apart from their cost.
Old Jun 10, 2012 | 6:42 PM
chevy619's Avatar
So a NTD is easier to install then?
Old Jun 11, 2012 | 3:59 PM
country_09's Avatar
On a NTD you don't drop the t-bars, but you have to install a mount on the lower control arm. Other than that, it's pretty easy and straightforward
mudmaniac
Sep 18, 2012 10:17 AM
Rlock4227
Feb 19, 2012 11:26 AM
zuren
Sep 25, 2011 11:09 PM
tahoe96
Jan 10, 2010 5:38 AM
sk8freak123
Apr 16, 2009 8:13 AM
