Oil Pressure Nightmare
Old May 4, 2008 | 7:35 PM
btechbish's Avatar
Default Oil Pressure Nightmare
can someone help me understand why i have no oil pressure all of a sudden, sensor is operational, changed filter thinking possible collapse, i was wrong.
after running 10 minutes tops, the valves are dry and making horendous noise, don't think the pump would go with only 62000 miles but not sure. any and all help would be appreciated, hopefully something a hack mechanic can deal with. thanks!
Old May 4, 2008 | 8:14 PM
northey87's Avatar
Default RE: Oil Pressure Nightmare
Welcome to the forum!!! That would be my guess, and if it is not the oil pump then you probably have a clogged line somewhere.
Old May 4, 2008 | 10:21 PM
shawnvw's Avatar
Banned
Oil pump, clogged oil pick-up tube, Loose\broken oil pick-up tube, plugged oil galleries, No Oil, etc etc. I'd start by checking the oil, then dropping the oil pan and inspecting the oil pick-up tube
Old May 9, 2008 | 7:28 AM
wellmax's Avatar
btech,
let us halfway mech know what you found on you truck. Lost of oil pressure is the fastest way to ruin a engine.
lost of coolant is second fastest way to ruin a engine.
what caused your problem and was it a easy fix or high dollar fix.
Good luck,
not_a_car_dude
Sep 15, 2013 7:41 PM
zone9man
Jun 23, 2007 4:18 AM
CliffGriffin
Jan 28, 2006 10:58 PM
vmx120
Sep 15, 2005 9:10 AM
Top
Follow Us
