oil pressure question 04 silv
Old Dec 9, 2007 | 5:04 PM
ShielaChevy's Avatar
Default oil pressure question 04 silv
i have an 04 silverado 4.8 4x4, and i was looking at my oil pressure gauge and it was going 50 to 60 psi normal driving is that normal for colder weather? it usualy only hits 50 psi when i am steping on it and stays around 40 most of the time is this something that i should take great concern with? thanks
Old Dec 10, 2007 | 10:36 AM
dleonard2844's Avatar
Default RE: oil pressure question 04 silv
I'm no pro here, but oil thickens up when it's cold, so it would seem that pressure would build up more easily. If it's only going to 60 i wouldn't worry about it, but if you're still concerned, maybe try switching to an oil better suited for winter use.
Old Dec 10, 2007 | 11:25 AM
ZX1100F1's Avatar
The normal oil pressure range for the 4.8L is 24 - 60psi @ 4,000 RPM so there is no cause for alarm.
Just make certain that you are using a good quality 5W-30 motor oil.
Old Dec 10, 2007 | 6:46 PM
cool right on thank you it is about due for an oil change too thanks alot
not_a_car_dude
Sep 15, 2013 7:41 PM
aftershock00
10
Sep 17, 2010 7:40 PM
mbaker1057
May 29, 2008 8:24 PM
carlsndfw
Jan 5, 2007 12:15 PM
PowhatanPete
Sep 3, 2006 7:25 PM
