Oil pressure switch 81 Blazer
Old Apr 20, 2007 | 12:07 PM
dark_waters's Avatar
Default Oil pressure switch 81 Blazer
Hi there everyone, here we go - first time to this forum and my first post.
I have a 1981 blazer with a 305.
After some extensive bodywork restoration over the past 18 months, i've got her back on the road. Since it was last run (18 months ago) its developed a major oil leak from the top of the engine, at the back (around the intake manifold)
I've got the inlet manifold off, and im doing the headgaskets,exhaust gaskets etc etcat the same time. I suspect the leak was from the intake manifold gasket as the olst owner bodged it all up with instant gasket.
However I have noticed that the oil pressure switch (near the distributor cap) revolves completely around in the block. The switch unit is tight on the shaft out of the block, but the whole sharft into the block revolves, it doesnt seem to tighten...is this normal or do I have another problem?
Ideally want to check this out before I put it all back together. Any help would be greatly appreciated.
Kind regards,
Rob.
Old Apr 20, 2007 | 7:53 PM
BrianE's Avatar
Default RE: Oil pressure switch 81 Blazer
sounds like the threads are stripped you need to get the tube and switch out and rethread the hole. It is pipe thread so you can go a larger size and adapt the tube down to the oil switch size. the oil tube must be tite and use pipe sealant this is most likely the source of your leak. On the Intake manafold I use High heat rtv silicone on the ends. BUT after you put it all back together let it dry overnight the silicone needs time to setup a lot of people make that mistake and end up with a leak.
Old May 17, 2007 | 11:51 AM
Thanks for the advise, replaced the union that screws into the block, engine is back together, no oil leaks!!
not_a_car_dude
Sep 15, 2013 7:41 PM
bbish0p
Nov 13, 2009 6:44 PM
bbish0p
Nov 12, 2009 2:54 PM
geozeke
Sep 16, 2009 7:50 AM
rtszolis
Feb 9, 2008 8:45 AM
