Oxygen sensor DTC P0036 will not go away.
Old Apr 24, 2012 | 2:30 PM
deepstuff's Avatar
Question Oxygen sensor DTC P0036 will not go away.
Had DTC P0036, Replaced drivers side post Cat sensor and reset DTC. P0036 keeps coming back.
’07 new body style 6.0L Vmax
Old Apr 24, 2012 | 4:52 PM
The problem may not be the Heated O2 sensor, it could be the wiring or even something else upstream of the sensor.
The code is the symptom the computer sees but not necessarily the actual cause...
I'd check the wiring and the connector to the sensor, it might be worth checking all fuses as well...
Old Apr 27, 2012 | 5:43 PM
deepstuff's Avatar
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> Now I`m getting P0036, P0054 and P0141
At idle HO2S12 = 440-600mv
HO2S22 = 195 -180mv
deepstuff
Mar 6, 2012 9:51 AM
giantswc
Cobalt
Feb 27, 2012 9:03 AM
arminkropp
Uplander
Mar 22, 2010 9:10 PM
myCHEVYkicksass
Apr 3, 2007 2:19 PM
chevy1
Aug 22, 2006 10:02 PM
