P0306 Codes
Old Oct 14, 2010 | 10:33 AM
Clutch City's Avatar
Default P0306 Codes
Hello all, I recently connected the code reader to my 1999 4.3L Chevy Silverado 1500, 2WD. I would get a code P0300, Multiple Misfire. So I did all the norms check the wires and spark plugs, distributer, injectors, etc. Found several injector hoses were cracked in the throttle body housing. So I changed the spider assembly out with a refurbished one. I used the Seafomed with good results. The truck ran great for one day, but started missing the next. So I hooked up the code reader again and got a P0306 code and P0440 emmissions. I pulled the number 6 plug and low and behold anti-freeze in spark plug well. What would this be an indication of? There is no water or antifreeze in oil. I have good vaccum, decent compression.
Could this be a bad head gasket, valve spring or what? Help!
jackalrs
Apr 8, 2014 10:47 AM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
Nels
Aug 26, 2006 2:22 PM
slingblade
Jun 8, 2006 2:57 PM
carplex2
Jun 7, 2006 5:45 PM
