PCM?
Old Oct 14, 2008 | 8:20 AM
chadt256's Avatar
Default PCM?
Im about to take my Pcm out to send to nelson tune. is it located against the firewall behind the fuse box. I have an 06 2500hd. little black box with two bolts at top and plug at bottom? and also how in the world do u unplug those plugs! every one under the truck i have nearly broke! i have squeezed and done everything i know.[]
Old Oct 14, 2008 | 9:13 AM
bad2006z71's Avatar
Default RE: PCM?
should be a black plastic cover to the left and down a little from the battery. the pcm is under that. just pull it off, its not bolted. then there should be a "snap" kind of clip that you unsnap (check for more than one). then you will be able to remove the pcm from there and then using i think a 7mm socket, unbolt the plugs from the pcm. then your done. reverse for installation.
chadt256
Oct 20, 2008 9:38 AM
Forgreed
Feb 16, 2008 8:01 AM
sschnelle
Dec 23, 2007 10:10 PM
rat55chevy
Mar 23, 2007 3:11 PM
Drock77
Mar 10, 2007 10:09 AM
