Pink coolant pouring out.
#11
#12
dexcool is orange not pink. Did they put an aftermarket coolant in...does what came out match what's in the reservoir?
The only time I've seen pink fluid in a gm is from trans fluid and coolant mix...so is the trans fluid over filled on the stick? Hope it's not a bad rad cause it's almost impossible to flush that out of a trans without tearing it down.
The original poster already confirmed it was a loose hose and the color only appeared pink. Case closed.
#13
you have never seen dexcool in a transmission then; as its not sludge. Its a watery pink coloured milkshake. I've had to tear one down after numerous fluid exchanges could not remove the contaminated fluid.
#14
Thanks for making my point. The picture he posted isn't a milkshake or however a person wants to describe it. It looks like a puddle of water with a pinkish hue. No signs of oil in it.
doityoureself
May 19th, 2011 7:50 PM
Eric3
August 6th, 2010 9:22 PM
godrocksus1
March 16th, 2010 6:59 PM
