please help diagnose the internal engine noise's
please help diagnose the internal engine noise's o7 trailblazer 5.3 6hl L33 engine.
either it's repairable inside the vehicle or I will attempt a engine swap thanks Chevy Guys for advice
.https://youtu.be/ZjpqHB8XBvQ
are you saying a spark plug is being pushed up where it leaks compression?if yes I can easliey check if a spark plug is loose and backing up.
I think it's upper end noise thought it was from cylinder 1 removed the rocker s on #1 good rockers all needle bearins intact.
both push rods are straight and I blew air though the rod.
should I crawl under the vehicle and video under there?
I don't have a compresion tester maybe I can rent one from auto zone. dam shame she was running strong before the ticking/knocking dam. thanks for advice
there's 2 noises the 1st fluttering is noise 1 the pinging is noise #2 this #2 is what I'm worried about more than the first flutting noise.
