please help diagnose the internal engine noise's
Old May 4, 2021 | 5:25 PM
the Brain's Avatar
Default please help diagnose the internal engine noise's
please help diagnose the internal engine noise's o7 trailblazer 5.3 6hl L33 engine.
either it's repairable inside the vehicle or I will attempt a engine swap thanks Chevy Guys for advice
Old May 4, 2021 | 5:51 PM
kevinkpk's Avatar
.https://youtu.be/ZjpqHB8XBvQ
Is it upper end noise? Do a quick compression check. I have an 02 Mazda that kept blowing the spark plug out, and that is what it sounded like.
Old May 4, 2021 | 6:09 PM
the Brain's Avatar
there's 2 noises the 1st fluttering is noise 1 the pinging is noise #2 this #2 is what I'm worried about more than the first flutting noise.
are you saying a spark plug is being pushed up where it leaks compression?if yes I can easliey check if a spark plug is loose and backing up.
I think it's upper end noise thought it was from cylinder 1 removed the rocker s on #1 good rockers all needle bearins intact.
both push rods are straight and I blew air though the rod.
should I crawl under the vehicle and video under there?
I don't have a compresion tester maybe I can rent one from auto zone. dam shame she was running strong before the ticking/knocking dam. thanks for advice
Old May 4, 2021 | 6:35 PM
kevinkpk's Avatar
You need to pinpoint where it is coming from. I have never been a fan of using a stethescope, but that might be what you have to do. My reference to the Mazda was actually blowing the spark plug out of the head, you don't have that issue unless you for some reason have a plug leaking.
Frank Torres
Mar 5, 2020 10:43 AM
Rodland
May 5, 2015 6:27 PM
itrustno1
Jan 16, 2014 5:36 PM
92astro
Jan 4, 2009 10:05 PM
DAYMAN
Jul 9, 2007 7:12 AM
