PO332 and PO315
PO332 and PO315
I was recently driving my 05 silverado and hit a fair size pot hole..After I hit the pot hole I noticed my check engine light came on. I went to auto zone and got the code no. PO332 and PO 315. From what info I gathered this is some type of sensor. Is this something that can be fixed by un-pluging the sensor and pluging back. I was really trying to avoid a visit to the dealership. Thanks for any help with this issue.
So, did they try to sell you a knock sensor? As for P0315, I don't see how the PCM can suddenly lose the crankshaft position variation learn factors. I think you'd be well advised to take it in for service, a reputable repair shop would do.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Isufan88,
I agree with EinST, I also would suggest you take the vehicle in for service. A certified technician should be able to offer a more accurate resolution with a physical inspection.
Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
