Po332 DTC knock sensor
Old Feb 16, 2014 | 4:35 PM
Desert Gringo's Avatar
Default Po332 DTC knock sensor
After washing the suburb, 2 days ago I got a ses..Po332 found it to be a knock sensor. I cleared it using my ultra gauge and after 30 miles it cleared itself from pending codes. so now it showed no TC's and no pending ...Now today took it on the highway the ses came back on, I keep the ultra gauge pluged in as it also give other vital info. ( same as a scan gauge, but cheaper) So while driving I cleared the code and after 10 miles I re checked the pendings and it was cleared also.. SO will it hurt the truck if I keep clearing this code out before I get a chance to replace sensors and harness?
I need to tow a camper to Cali in a week or 2 so I really don't want to tear it apart and not be ready or screw something up while taking it apart, .. so just need to know if clearing the code is ok for the time being. thank you
Old Feb 23, 2014 | 5:40 PM
so after researching other forums ,it is ok to keep resetting/clearing the code p0332
as the burb does not start to run bad at all. SO until I have the time I guess clearing the codes is what will be done till then.
Suburbman
Jan 31, 2025 7:02 AM
lsufan88
Feb 4, 2012 10:31 AM
USR_BS
May 27, 2010 10:46 AM
jffgin
Mar 10, 2008 2:32 PM
