Popping sound when driving at low speed
Old May 7, 2013 | 4:43 PM
jheffley81's Avatar
Default Popping sound when driving at low speed
So I recently replaced the ball joints and tie rods on my 1995 Chevy K1500. After taking it for a road test later in the evening while out driving I was driving through a parking lot at a slow speed when I noticed a popping sound in my vehicle, I could feel it like I had a bad tire. The pop was just about every tire rotation. After leaving my pickup parked I went to move it an it ran fine, now everyonce in awhile to popping will come back and then go away once I leave it parked. I took it to a shop and they told me I had bad U-Joints. I took it to another shop and they told me there is nothing wrong with my U-Joints and were kind enough to talk me through a walk through of the bottom of my truck. Since the popping doesn't always happen it is difficult to pinpoint the problem. However, while on the lift with everything free hanging my driver side tire will not spin. Once it is positioned at travel height then it spins no problem. Could my CV axle be what is causing me the problem?
Old May 7, 2013 | 6:36 PM
Allan In NE's Avatar
That or a cracked wheel maybe?
Allan
Old May 9, 2013 | 8:46 PM
ukrkoz's Avatar
Aftermarket ball joints? How did you replace them? It's ball joints stud popping in hub knuckle.
Old May 10, 2013 | 1:22 PM
jheffley81's Avatar
Just basic ball joints from Autozone, used a ball press to get them in place. I keep checking them and they appear to be seated fine. Like I said it doesn't happen all the time so it is difficult to pin point the problem.
Old May 10, 2013 | 6:32 PM
jheffley81's Avatar
So today while pulling into a shopping center popping sound started again and definitely coming from the driver side tire area. If it is the new ball joints are they bad? Do I need to replace them or perhaps did I overlook something?
Old May 10, 2013 | 8:49 PM
ukrkoz's Avatar
You should have asked me how I know. I had all 4 control arms with Bjs installed replaced. Though they do LOOK fine and seated well, I have, at shart turns when taking off, exactly that - pop in the driver side.
I almost guarantee you they are not seated right and pop. Autozone is not known for the best quality product. I care less, I am selling mine.
Old May 11, 2013 | 11:12 AM
cleveland63b's Avatar
im banking on cv axle just for the fact you said it wont spin when fully flexed, balljoints would have nothing to do with the tire/hub itself spinning
Old May 11, 2013 | 8:28 PM
ukrkoz's Avatar
Old May 13, 2013 | 12:13 AM
cv axle isnt a ujoint
Old May 13, 2013 | 12:29 AM
balljoints/controls arms WOULD NOT keep the wheel from spinning, wheel not spinning=binding and binding=popping when the force lets loose
balljoints not seating would be installation error not a part error unless they are falling out of the control arm which would be noticeable, personally i have never heard of balljoints causing a noise concern of any kind unless they were super loose or about to come apart
on another note even though I doubt they're related at all how did they check the ujoints? Its hard to tell if a joint is actually bad or not without removing the driveshaft.
my vote is the CV axle shaft
mackda600
Sep 14, 2012 9:35 PM
philip.camp
Oct 13, 2011 11:10 AM
loveandrockets
Cobalt
Aug 26, 2011 6:44 PM
tonzmn
May 15, 2009 12:06 PM
