Power steering hose help
Old Nov 29, 2013 | 9:32 PM
gray gables's Avatar
New User
Awaiting E-mail Confirmation
Default Power steering hose help
Blew a hose tonight pulling out of my driveway, pulled back in and looked at it best I could in the night. Looks like it came off of the metal tubes that is sticking up, has this happened to anyone and is it easy to fix? I looked on youtube for some help but didn't see anything. I'll check back tomorrow sometime on this, thanks matt
Old Nov 30, 2013 | 12:08 PM
New User
looks like it was my return hose, I clamped it back on filled the pump with new fluid but now it won't work at all? Do I need to bleed my system to get the fluid in the lines?
Old Dec 2, 2013 | 3:32 PM
mel902's Avatar
If it did not run totally dry it should work.After you top it up with fluid let the truck idle and turn the steering wheel slowly to the left and then to the right to remove he air. Do this a few time and the air should work itself out.
If this does not work,it might be it might be the pump itself. Was it whining before the hose blew? Does the oil smell burnt?
I would buy new return line just incase the one you have might be collapsed ,they are fairly cheap around 20-25 bucks and easy to install.
jlutty3
Avalanche
Feb 27, 2020 6:41 PM
Papa Bear
Uplander
Jul 29, 2015 4:14 PM
jdog0411
Feb 11, 2013 9:53 PM
ed72073
Oct 15, 2010 11:52 AM
robbiestuff
Jul 17, 2006 11:41 AM
