Problem between headlights, blinkers, and running lights
Hey guys I have an interesting problem and since I'm not a big wiring and electricity guy I'm hoping someone can point me in the right direction with what to do. First off I have a 91 1500 5.7 350. My problem is when I have my headlights or just parking lights on my blinkers and running lights don't work. Sometimes I'll get a dim flash or two, but nothing more. Without my headlights on though everything works fine. If I put the blinker on with my headlights on then turn the headlights off it will immediately start blinking and my temp control box and radio will blink a few times in sequence with the blinker. Not sure where to go with this. In my research I have heard to look at the grounds, so I'll do that later this evening. Any other suggestions would be much appreciated. Thanks!
hey stank, I was having the same problem with my 1994 Silverado, after a lot of poking and proding, I landed at the headlamp switch ( in the dash) I replaced the switch and now im good to go
java4iv
December 22nd, 2014 9:37 AM
Samanthastevens
October 17th, 2010 8:08 PM
skdevore
August 26th, 2009 10:18 PM
