Problem with brake lights on a '96 Silverado
Old Sep 18, 2007 | 3:10 PM
Drewless's Avatar
Default Problem with brake lights on a '96 Silverado
Hey All,
I've got a '96 Silverado and my brake lights no longer work.
I've replaced the relay and the switch and still no lights...what should I check next?
Old Sep 18, 2007 | 4:26 PM
ZX1100F1's Avatar
Default RE: Problem with brake lights on a '96 Silverado
Check the bulbs and sockets and make sure that all fuses are good.
Then check the wiring underneath the bed/cab and connectors
When you say that you "replaced the switch" I assume that you mean the brakelight switch down at the pedal?
Does the truck have a trailer brake controller?
Old Sep 18, 2007 | 5:52 PM
Drewless's Avatar
Yes the switch by the pedal and the fuses and bulbs are all fine.
There is a harness for trailer lights and I took out the splitter for it, but still no luck.
I'm not sure of where else to check...
PatrykKoul
Apr 26, 2023 9:14 AM
TRUCKDIVA
Jul 22, 2013 6:48 AM
DOBERDEWD
Dec 11, 2011 11:35 PM
skdevore
Aug 26, 2009 10:18 PM
cowboys
Dec 18, 2006 12:28 AM
