problems trying to do a brake job c2500 fwd
I'm trying to do a brake job on my 93 c 2500 fwd 6.5 turbo diesel.
The chilton book does not tell me how to get the rotor off.
I've undone and removed the caliper, loosen the center nut. The spline seems to move freely but i still can't get the hub loose. I know i'm probibly missing a step. Can anyone help?
Thak you
Thak you
if this is a 4x4 then all you gotta do on a 6 bolt hub is hit the rotor and it will come off, if it is an 8 bolt then I think you gotta take the hub and rotor off as an assembly by removing the bolts in between the control arms
littlelove
Traverse
May 30th, 2015 9:25 AM
