Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, K2XX Why Does Truck Pull Right
Guide to diagnose trouble and recommended solutions.
Pulls to the right
for the speed sensor on mine, the wire leading from the wheel was worn in one spot and was missing some insulation. I thought maybe some salt and grime had gotten on the wire and was making the sensor act up. Your problem doesn't really sound like the speed sensor, but if you can't figure out what the problem is otherwise then you can check into it I guess
To Cam3439, thanks so very much for the info on the brake lines. YOU HIT IT RIGHT ON THE HEAD!!! again thank you. The drivers side line was the issue, I replaced it first to try it, it solved the issue, so I ran out and got the other side for good measures.
To everyone else that assitted me with idea's and solutions to try, thank you again... Awesome job...
Thanks
Thanks
