Putting axle bearings again in
Hello,
Truck : chevy silverado 1994 C1500 standard cab.
I've pulled the axle bearings out with a slide hammer. But I can't get the new ones in. What can I do ?
Thanks
Thanks
make sure the housing is cleaned well, if I remember right, its been awhile you should be able to get em started, then take a socket the same size as the outer part of the bearing, put against bearing, and hit with a hammer until the bearing is seated where it needs to be.
VanGo
January 21st, 2011 8:40 AM
Speedy650
October 10th, 2009 7:01 PM
Toby T
March 10th, 2007 5:48 AM
Travis G
November 30th, 2006 1:45 AM
antmesa
August 28th, 2006 3:35 PM
