A Q's about my 08 LTZ
Old May 8, 2008 | 2:10 PM
Smooth08LTZ's Avatar
Default A Q's about my 08 LTZ
It's been 18 years sense my last "BIG BOY" truck. Think Dakota, Colorado, S10..... Well I love it so far but have a few Q's. It has the VortexMAX 6.0 and I was wondering why the hell it will not smoke the tires from a stand still (with tracktion control off)? Not that I want to all the time , it's just sometimes ya want the big dog to eat. What size motor is the 6.0 in inches....350ci? I forgot my middle school math and it hurts to try. Also, just wondering if anyone has had any problems with there 08 crew w/6.0?
2008 Silverado 1500 Crew Cab Short Box LTZ 4X4 Summit White
Old May 8, 2008 | 3:18 PM
bad2006z71's Avatar
Default RE: A Q's about my 08 LTZ
according to my little converter thing 6.0ltr is 366 cubic inches. as for not being able to roast the tires, i know the old body style 99-07 chevy's have a tourqe management system which basically depowers the truck in order to prevent spinning tires or doing burnouts. basically chevy cant stop producing the weak 4l60e transmission (basically an updated version of the old weak 700r4) so they put that in to prevent excessive wear on the drivetrain.
the only way to get rid of it is to use the predator tuner or get a custom tune. i know my truck has a really bad delay when you hit it WOT before it will pick up and go.
i dont know if the new body style trucks are the same or not. i thought that the Vortec max package gave you a super duty transmission. not sure though.
Old May 8, 2008 | 7:44 PM
tahoe07's Avatar
The problem is the programming. This is an excerpt from an Edmund's report explaining why the dyno numbers seemed off on the 6.0 they tested
Might be the same for the 5.3
As it turns out, the explanation boils down to an engine calibration strategy. GM calibrated the 367-hp 6.0-liter V8 to remain in stoichiometric "closed-loop" fuel delivery mode for 4 seconds after the throttle is floored. This fueling strategy helps keep emissions in check (and saves fuel) at the expense of reduced power — about 40 hp less at the peak. Once the driver lifts his right foot from the wide-open throttle position, the 4-second clock resets.
This explains why the Silverado's power is low everywhere on the graph right up to the jump in power right before redline. Corresponding to the expiration of the 4-second window, the jump in power is indicative of the engine switching to open-loop "power enrichment" mode. It is only when operating in this mode that the engine delivers its full rated power.
Release the hounds
On the road, the Silverado's full advertised power will be on tap during extended full-throttle conditions such as towing, or any other situation in which the throttle is floored for more than 4 seconds.
Be aware, however, that the Silverado's horsepower herd will be thinned out during all but the most prolonged wide-open throttle squirts around town. And with an empty bed and no trailer, 4 seconds is a fairly long time to have the throttle matted.
Old May 8, 2008 | 8:26 PM
cheaperrooter's Avatar
15 Year Member
Is this only a full stomp....I mean if I floor it without bottoming out pedal, like 6/8 of the way, am I safe from the 4 sec delay?
Old May 8, 2008 | 8:28 PM
15 Year Member
Also Tahoe, is there anyway around this??? Special chip or something to remove the 4 sec delay? I just bought a work truck version 6.0.....maybe it doesn't apply to the work truck (crossing fingers) (too lazy to get up and go for a drive to find out)
Old May 8, 2008 | 8:41 PM
sierra_5300's Avatar
I have no problem smoking the tires down on my truck it will keep spinning until you left off the gas. No i dont have chicken **** tires i have 20's and i will light them up. I have a 2006 model the new models are no where near as fast as the older ones. My friend has the exact truck as mine but 2008 model i will smoke him 0-60 quarter mile whatever. All that extra active fuel management **** slows it down alot there is a huge delay the throttle. sone to come whipple, heads, cam
check out this video, someday!
http://vids.myspace.com/index.cfm?fu...ideoid=5335238
Old May 8, 2008 | 8:46 PM
15 Year Member
You know, this 4 sec thing has got me worked up. I mean I have a 4x4 work truck. For christs sake, when I hit the gas, I need the power. How are you supposed to 4 wheel with a 4 sec delay?
Old May 8, 2008 | 9:42 PM
northey87's Avatar
Smooth08LTZ, welcome to the forum!!!
Old May 8, 2008 | 11:54 PM
silveradolt1's Avatar
my 03 takes off crazy wen i go WOT, why is that and it can burn them up nice
Old May 9, 2008 | 11:11 AM
My G/F has a 2000 and that thing will roast a tire just looking at it wrong!!! I did notice I could power brakethe 08and spin the tires but I did not go all out or for 4 secs though. Running 20's and them eagles aint cheep. Someone power break the 07/08 6.0 all out and for more then 4 secs and let me know what happens. I would but I only had her for a week now....don't want to hurt the girl. Thanks for all the info.
Top
Follow Us
