Notices
Rear end differential
Old February 10th, 2007, 3:49 PM
sm3earl's Avatar
Default Rear end differential
Hey, i have a 2000 chevy 1500 2WD, does anyone know if it is an open differential or limited slip, my truck is a LT2.
Thanks in advance
-shawn
Old February 11th, 2007, 10:43 PM
Banned
Waboom!!'s Avatar
Default RE: Rear end differential
I dont know. Dealers in different regions order different options. I would research the VIN and get a build sheet from the dealer. They are extremely helpful when replacing parts and will be great for if and when you sell the truck.
Old February 12th, 2007, 1:57 AM
sm3earl's Avatar
alright, would i just go to a chevy dealer and ask for a build sheet?
-shawn
Old February 12th, 2007, 1:58 AM
shnormo's Avatar
that or look on the front side of the passenger tube.
Old February 12th, 2007, 2:05 AM
sm3earl's Avatar
the tube of what?
thanks
-shawn
Old February 12th, 2007, 2:12 AM
shnormo's Avatar
The axle tube
Old February 12th, 2007, 2:13 AM
Banned
Waboom!!'s Avatar
get a real build sheet, code tags won't help much a s far as lay mens terms.
Old February 12th, 2007, 2:14 AM
shnormo's Avatar
are you planning to change the gears too? Seems like if you are, leave that to a professional. It is fairly complicated to change gears and the average D.I.Y.er can not do it. You have to set the right pinion depth, backlash, and you'll need a special run out meter.
Old February 12th, 2007, 2:25 AM
sm3earl's Avatar
alright ill take a look at it tmr morning.
I am not planning on changing gears i just want to put in a limited slip unless it already has it.
Where would i get a build sheet at? online? chevy dealer?
Thanks for your help
-shawn
Old February 14th, 2007, 12:26 AM
Banned
Waboom!!'s Avatar
well lets just say the chevy dealer wouldn't be a bad place to start!
Quick Reply: Rear end differential
