Rear end differential
Old Feb 10, 2007 | 3:49 PM
sm3earl's Avatar
Default Rear end differential
Hey, i have a 2000 chevy 1500 2WD, does anyone know if it is an open differential or limited slip, my truck is a LT2.
Thanks in advance
-shawn
Old Feb 11, 2007 | 10:43 PM
Waboom!!'s Avatar
Banned
Default RE: Rear end differential
I dont know. Dealers in different regions order different options. I would research the VIN and get a build sheet from the dealer. They are extremely helpful when replacing parts and will be great for if and when you sell the truck.
Old Feb 12, 2007 | 1:57 AM
sm3earl's Avatar
alright, would i just go to a chevy dealer and ask for a build sheet?
-shawn
Old Feb 12, 2007 | 1:58 AM
shnormo's Avatar
that or look on the front side of the passenger tube.
Old Feb 12, 2007 | 2:05 AM
sm3earl's Avatar
the tube of what?
thanks
-shawn
Old Feb 12, 2007 | 2:12 AM
shnormo's Avatar
The axle tube
Old Feb 12, 2007 | 2:13 AM
Waboom!!'s Avatar
Banned
get a real build sheet, code tags won't help much a s far as lay mens terms.
Old Feb 12, 2007 | 2:14 AM
shnormo's Avatar
are you planning to change the gears too? Seems like if you are, leave that to a professional. It is fairly complicated to change gears and the average D.I.Y.er can not do it. You have to set the right pinion depth, backlash, and you'll need a special run out meter.
Old Feb 12, 2007 | 2:25 AM
sm3earl's Avatar
alright ill take a look at it tmr morning.
I am not planning on changing gears i just want to put in a limited slip unless it already has it.
Where would i get a build sheet at? online? chevy dealer?
Thanks for your help
-shawn
Old Feb 14, 2007 | 12:26 AM
Waboom!!'s Avatar
Banned
well lets just say the chevy dealer wouldn't be a bad place to start!
