Rebuilding motor
Old Jan 16, 2014 | 9:55 PM
97chevyproject's Avatar
Default Rebuilding motor
I have a 97 Silverado that had 200,000 miles on a 5.3 vortec fuel injected motor. I pulled that engine out. I pulled another 5.3 from an old camper that only had 50,000 miles on it, this one was throttle body injected though. So I took the block from the throttle body injected motor, rebuilt the top of the fuel injected motor, and put it together. I noticed that the heads from the tbi motor are higher than the ones from the fuel injected motor. Now my lifter rods are too short. So the question is, what sized lifter rods should I get to make this work?
Old Jan 17, 2014 | 11:22 AM
Will the lifter rods from the other motor work?
Old Jan 19, 2014 | 7:46 PM
They might of but I sold them with the other heads not even thinking about this problem, so now I'm not sure what size ill need.
Old Jan 20, 2014 | 12:40 AM
Dropped95gmc's Avatar
You should be able to go to any parts store and get a set for a Vortec motor, and they will work. The heads and injector setup are the main difference in a TBI and Vortec motor. Hope this helps
98SilveradoK1500
Jun 12, 2013 1:05 AM
ericch
May 26, 2007 12:54 AM
QuazyQ
Jul 3, 2006 7:52 PM
