Reduce Engine Power
Old Jan 22, 2013 | 6:37 PM
coopdogx's Avatar
Default Reduce Engine Power
Ok so I got reduced engine power on my vehicle and I was unable to drive it faster than 5 mph. Throttle body and pedal sensor was replaced. 3 weeks passed and the problem came back except this time I could accelerate up to about 30 mph. This persisted and the throttle body and pedal sensor has been replaced 4 times. In addition the wiring harnesses, ground wire, and alternator has been replaced as well. This worked for about a week and the reduced engine power has come back again. Any suggestions?
Old Jan 22, 2013 | 8:39 PM
Fishinfooleric10@aol.com's Avatar
Knock sensor maybe? Ive heard of that happening with earlier models like 04 and 05
Old Jan 23, 2013 | 12:25 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> coopdogx,
I’m sorry you are experiencing this issue with your vehicle. What year is the vehicle? Where was the work performed?
Louis
GM Customer Service
04YukonAWD
Mar 8, 2015 1:37 PM
drj3253
Jan 13, 2014 4:10 PM
moni
Sep 7, 2013 7:57 PM
anthony2261
Avalanche
Aug 26, 2010 1:12 PM
