Notices
Reduced Engine Power / Oscillating RPM
Old January 31st, 2013, 7:53 AM
jayteewilson's Avatar
Default Reduced Engine Power / Oscillating RPM
I have a 2004 Silverado with a 5.3L. I have two problems, not sure if they are related.
First one is when I have driving at a steady speed my RPM raises and lowers about 200rpm. I have been trying to see if the problem happens at a specific point, temperature, etc... but can't find anything.
Second problem is about once or twice a week, the Reduced Engine Power message appears, the truck slows down and I don't have any power, I pull off to the side of the road, shut everything down, restart and the truck is fine till the next time.
Any suggestions?
Oh yeah, the truck has 270,000 miles on it.
Thanks in advance for any help.
Old January 31st, 2013, 6:20 PM
you probably have drive by wire throttle control; no throttle cable. The problems most likely are related.
With this system any problems with the throttle actuator or pedal position sensor and related wiring will cause the system to enter fail safe mode; which it is doing.
Have the dtc scanned. It may be better to have it diagnosed by a professional.
AllenC412
April 29th, 2022 1:31 AM
cdelta1975
December 4th, 2019 12:56 AM
ts18997
June 19th, 2014 6:53 PM
vivero
June 24th, 2007 12:23 PM
vivero
June 23rd, 2007 2:38 PM
Quick Reply: Reduced Engine Power / Oscillating RPM
