Reduced engine power/stabilitrac warning lights.. loss off power
Old Jan 20, 2020 | 7:57 PM
reginald buckmon's Avatar
Default Reduced engine power/stabilitrac warning lights.. loss off power
Hi. I'm new to this forum but I have read a lot of old posts about people having this issue with many different reasons. I have a 2010 Chevy silverado 1500 5.3.. I myself was towing my boat when these lights came on and the engine basically died out on me. I've since changed the battery, the camshaft position sensor, crankshaft position sensor, and the throttle body position sensor and it still wont start.. It will turn over but won't start like it's not getting any fire. I've checked all the fuses and all good.. I hear there was a special recall for the throttle body.. Does that still apply? I also see some say the onstar computer could be the issues.. ANY HELP!!!
Old Jan 21, 2020 | 11:57 PM
oilcanhenry's Avatar
Can you get us some OBD II codes? That might help quite a bit in Dxing your issue.
Old Jan 22, 2020 | 4:09 PM
the only code was showing was for the camshaft position sensor . I started there then on to crankshaft, then the throttle body sensor. When I changed the battery all the codes went away but still wont crank
Old Jan 24, 2020 | 6:18 PM
Are you getting a good solid spark?
Old Jan 24, 2020 | 7:52 PM
its got spark.. but its still sounds kind of sluggish as it turns over
Old Mar 3, 2020 | 10:16 PM
keithwarfield601@aol.com's Avatar
I replaced spark plugs and wires and this seems to have solved my problem. Its only been 8 hrs but all is well so far.
GRAHAMR
HHR
Dec 10, 2016 10:53 PM
Cpt. Firepants
Nov 29, 2016 11:10 AM
tr16
Jan 11, 2015 7:53 PM
dppercle6
Dec 10, 2014 9:53 AM
