Remote key fob
Old Nov 28, 2011 | 4:13 PM
rtg143's Avatar
Default Remote key fob
I have a 2002 Silverado 1500 LS and only had one remote. I found one from a 2001 Corvette and programmed it to my truck. Everything works except the trunk button. Which I don't have anyway.
Old Nov 29, 2011 | 10:03 AM
Tym C's Avatar
How did you program the new remote? I only have one as well and would like to buy another but dont want to pay the dealer to program it. I was told its just holding in the lock and unlock buttons in (at the same time) while standing next to my truck.
Old Nov 29, 2011 | 11:19 AM
rtg143's Avatar
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
11. Repeat step 10 now for each additional transmitter (including any existing transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
Old Nov 29, 2011 | 11:30 AM
Tym C's Avatar
Thank you.
Old Jun 27, 2012 | 1:01 PM
MorrisGray's Avatar
my oem key fob is p/n 15042968
what is the number on your vette fob that worked?
kcarberry
Jan 24, 2014 5:37 PM
jpsilk2264
Apr 5, 2011 9:30 PM
chevykicksbut
Oct 23, 2010 12:32 AM
73shark
Nov 22, 2008 9:34 PM
onegodapostolic
Sep 29, 2008 9:53 PM
