remote start, tach and fuel pump wires?
Old Apr 7, 2008 | 1:39 AM
northey87's Avatar
Default remote start, tach and fuel pump wires?
I am installing a remote starterin my truck and I need to find a tach wire to hook in to. Does anybody know where this wire would be? and is the fuel pump circuit active when the ignition is on or what activates it? I can get to turn over but it won't start and I think it is because of one of these two reasons. The truck starts fine if I use the key.
Old Apr 7, 2008 | 5:17 PM
shawnvw's Avatar
Banned
Default RE: remote start, tach and fuel pump wires?
There should be a white wire on your coil, this will be a good tach reference.
When you hooked up the remote starter, did you get both the pink and white ignition wires?
Old Apr 7, 2008 | 7:26 PM
northey87's Avatar
I hooked up the to the pink with a white stripe, but no white wire. Here is what I have hooked up the yellow crank/starter wire, pink ign. wire, and the brown acc. wire. Is there suppose to be a white wire?
And which white wire ontop the coil? There are three, one from a black connector, ne from a grey connector, and one tha comes through the loom but stops just before the coil.
Old Apr 8, 2008 | 12:29 PM
northey87's Avatar
I know why I can't get it going, I have no power to the feul relay when I use the remote start. What wire do I need to connect to? And I still don't know which white wire on the coil you are referring to.
Old Apr 8, 2008 | 2:55 PM
northey87's Avatar
Nevermind, I figured it out, everything works. thanks
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
iego
Nov 17, 2012 10:12 AM
hunter10220
May 18, 2011 8:37 PM
tonynikki0181
Mar 12, 2009 12:47 PM
Top
Follow Us
