Removal of a body lift
Old Aug 5, 2014 | 11:51 AM
Murdered Silverado's Avatar
Default Removal of a body lift
My name is Austen I drive a 2011 Silverado 1500 LS 3 inch body lift with leveling kit in the front on 35 inch tires. I'm about to take the lifts off and put it on smaller tires but I wanted to ask if you need stock parts after you take a body lift off? If so what parts? I bought it with the body lift on it. Thanks for the help in advance!
Old Aug 5, 2014 | 6:46 PM
country_09's Avatar
I believe stock front/rear bumper brackets an then the original body bolt hardware since the body lift required longer ones
Old Aug 6, 2014 | 11:04 AM
So do you think if I had someone with a 2500 2013 that I could use what's under their truck? Or should I just go buy those parts?
Old Aug 6, 2014 | 2:24 PM
country_09's Avatar
Wanna say it could work, but not sure on front bumper brackets. If body bolts are same length then those could be used. Would have to pull it off that truck and see. Would prolly be best to buy parts. Front brackets aren't buy able I wouldn't think, they're welded to the frame
Old Aug 7, 2014 | 10:37 AM
Thanks a lot for the help!
RUTRAKIN
Aug 7, 2015 11:05 PM
Aerosol
Jan 26, 2015 10:06 AM
mikekelso99
Jan 8, 2015 9:22 PM
Murdered Silverado
Site Feedback
Aug 1, 2014 12:01 PM
dtizz
Oct 10, 2012 3:09 PM
