Removing dash
Old May 4, 2006 | 6:28 AM
redneck's Avatar
Default Removing dash
hi all
just checking to see how hard it is to remove the dash in order to change the radio on a 96 silverado.
is there a easy way that it comes apart.
cheers greg
Old May 4, 2006 | 11:14 AM
Nomad76lj's Avatar
Default RE: Removing dash
i think the trim is just cliped in around the radio. if not then its just a few bolts holding it in then once you get the trim off its 4 bolts holding the radio itself in. hope that helps.
Old May 17, 2006 | 2:49 PM
Chevrolettruckman8's Avatar
the whole face plate for the gauges/radio/ A/C is one trim piece, you pop it off and on..........you do it by hand pulling on it(carefully) to save some time you need to put the keys in and not start the truck but move the automatic shifter down into first gear. Doing so will provide you with some extra space when pulling off the dash panel to move it cleanly away and pull the trim off the bottom clips around the steering colum.
jealousblues
Jul 1, 2013 11:14 AM
nauticstar87
Mar 29, 2010 10:06 PM
throne7
Jul 21, 2009 1:00 PM
delahoya
Feb 2, 2006 4:38 PM
