removing tailgate with camera
Old Aug 1, 2014 | 10:10 PM
rafter's Avatar
Default removing tailgate with camera
I have a 2015 3500 with a tailgate camera. Manual is no help. I have traced the wire to a plug connection but even after moving a small red latch on the connector, I cannot remove the plug to allow me to remove the tailgate. Anyone with a 2015 that has figured this one out?
Old Aug 2, 2014 | 12:38 AM
the red latch is a lock. once the latch is slide to unlock, you probably will find a tab that needs to be pressed, then pull the connector apart
Old Aug 2, 2014 | 10:12 AM
Ronin1014's Avatar
Tech2 hit it on the head, it's just a lock clip. Look over the connector to find the tab, you might need a small flat head screw driver to help push the tab down (DO NOT PRY), but there will be a push tab on there.
Jonathan White
Oct 17, 2009 3:00 PM
groundupkustoms
Jan 22, 2008 11:00 PM
hayseed
Jan 8, 2007 10:58 PM
redtop
Jul 27, 2006 7:29 PM
bosschevy
Jun 6, 2006 10:57 PM
