Replaced oil pressure sensor, cylinder 1 misfire
Took my truck to a mechanic to replace the oil pressure sensor and when i went to pick it up it had a miss on cylinder 1. The plug wire and coil has been replaced. What else could it be and how in the world are the 2 even remotely connected? 2008 chevy silverado 1500 with 5.3
they are not related.
Is it a dead miss that is there at all times?
swap the plug with another cylinder and see if the misfire stays with the plug. if it doesn't do a compression check. I believe cyl 1 is an afm cylinder...if you have no compression, the afm lifter may have collapsed. did you run it out of oil?
not_a_car_dude
September 15th, 2013 7:41 PM
Trupster
July 8th, 2007 6:26 PM
adambraap
January 28th, 2007 9:58 PM
akimber
14
August 22nd, 2006 11:45 AM
