Replaced oil pressure sensor, cylinder 1 misfire
Old Mar 9, 2015 | 7:38 PM
RBurley's Avatar
Default Replaced oil pressure sensor, cylinder 1 misfire
Took my truck to a mechanic to replace the oil pressure sensor and when i went to pick it up it had a miss on cylinder 1. The plug wire and coil has been replaced. What else could it be and how in the world are the 2 even remotely connected? 2008 chevy silverado 1500 with 5.3
Old Mar 9, 2015 | 7:52 PM
they are not related.
Is it a dead miss that is there at all times?
swap the plug with another cylinder and see if the misfire stays with the plug. if it doesn't do a compression check. I believe cyl 1 is an afm cylinder...if you have no compression, the afm lifter may have collapsed. did you run it out of oil?
Old Mar 9, 2015 | 9:25 PM
RBurley's Avatar
The miss is there all the time, didnt run out of oil in fact i had too much oil when i sent it in.
not_a_car_dude
Sep 15, 2013 7:41 PM
Trupster
Jul 8, 2007 6:26 PM
adambraap
Feb 16, 2007 7:49 PM
adambraap
Jan 28, 2007 9:58 PM
akimber
14
Aug 22, 2006 11:45 AM
