Replacement Driveshaft
Old Oct 24, 2011 | 5:48 PM
TCMars's Avatar
Default Replacement Driveshaft
Issue
I put a big dent in my driveshaft. Although I'm not feeling any serious vibrations I've been told that it needs to be replaced ASAP. I've noticed there are a lot of driveshaft manufactures out there and I wanted to see what was recommended.
Vehicle
Year: 1996
Model: 1500
Engine: 5.0L V8; 4WD
Current driveshaft appears to be aluminum.
Comments
I do tend to abuse this truck and have been known to do some off-roading (probably how the dent got there). Maybe that impacts which driveshaft I should pick up. Also, I will be doing this myself. Thanks for any advice!
Old Oct 25, 2011 | 7:04 PM
nj85z28's Avatar
Senior Site Administrator
I broke my stock shaft on my 05..ended up getting the spicer replacement from GM. I would recommend replacing it with the factory piece unless you can justify the cost difference if any
gilbertaarnesson
Astro
Sep 3, 2007 1:55 AM
keebeaux
Aug 26, 2007 8:26 PM
.:fLiPt:.
Jun 27, 2007 1:34 PM
huskersdomn8
Feb 22, 2007 11:23 AM
BassTracker
Jul 14, 2006 9:11 PM
