Replacing 4L60e; now its stuck to the engine
![Lightbulb](https://chevroletforum.com/forum/images/icons/icon3.gif)
hi all, I decided that my best bet in fixing my 95 1500 with the bad tranny was to just replace it. i bought a recently rebuilt model off craigslist for 300 bucks and set off the do the swap.
I bought the haynes manual and followed all the instructions. it is pretty straight forward. I am at point where I just finished unbolting the old unit from the engine. my problem is that it is stuck to the engine. I have tried jacking the transmission up a bit, and then letting it down to the point where it is hanging there. I have also whacked at it with a 4lb hammer (busted the tailshaft of the old one
) but to no avail.
Anyone have an ideas? I have an air chisel but I think that would jack up the engine itself.
Let me know what you all think, i'm open to anything since I'm stumped.
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
you are in luck! yesterday i pulled the motor out of mine, so here we go: there are 6 bolts that hold the trans to the motor, ( 15mm or 9/16 heads) if two were 13mm you are not done, go after the rest of them. then there are 6 15mm headed bolts that hold the flywheel cover on plus 2 bolts on the struts - 4X4, the 2WD has 5 or 6 10mm headed bolts. that should be it
97chevyrichie
May 13th, 2014 9:59 AM
abqgolfer
August 27th, 2011 11:30 PM
BlackDenali
January 17th, 2008 10:01 AM
larry_chip
April 24th, 2007 11:46 AM
