Reviving a C1500 after 6 years! O.o
#11
About TBI, I was mistaken, it is CPI. Not sure what the difference is, but I read a post somewhere and they were discussing it. I guess it's a newer TB design for the Vortec?
At any rate, I don't know what/where a fuel pressure regulator diaphragm is. But I will definately look into the IAC or idle whatever.
#12
Ok, the cylinders weren't frozen. I bled them, shot out dirty brown and even some pitch black fluid then clear and they started moving again. Passenger side has a rotted seal on the front piston, but it's moving just fine. Strong pedal, all 4 corners push as they are supposed to, so that's 1 case closed.
Took your advise and tried to seek out this idle controller. I found 2 different 2-wire connections are the TB. If I read the Haynes correctly, this first picture is what I should be looking for. Or maybe it's the 2nd picture..
Picture #1 (Also, is that bottom line really supposed to be open like that? When I went to put this part on, it already had that line connected like that, and there is another line going behind the engine to the other side to something.)
Picture #2
Also, once we got the engine all wrapped up, there was 1 loose connector with nothing in sight that would connect to it. It screws into the side of the head on the driver's side. It's between the middle and rear exhaust runners. I have had myself and about 4 other people look for a matching connector and nothing can be found. I THINK it is the a coolant temp sensor, because the temp gauge doesn't work on the dash.
Picture of it. Connector is in my hand and you can barely see where it screw into the head.
Connector by itself
Other end that screws into the head.
Picture #2
Connector by itself
#16
yea, show me the pics but the 2 spade connector in the head between the #1 y #2 headers is the Coolant temp sensor for the IC. There is ANOTHER one specifically for the computer located by the Thermostat.
I did this 2x over the summer in both my Chevy trucks so if you replace it the best place to get it was Ebay and put a bucket under it when you pull it because all the coolant will come out with it.
Upload the pics again but smaller and I ll see what you re referring to.
#17
Pics are fixed again, I think.
And I don't think there is anything wrong with the temp sensor (if that's what it is). I just can't find the other connector to actually plug it in.
Choop101
June 18th, 2014 5:40 PM
mdisco77
10
August 4th, 2013 6:32 PM
Chevrolet Forum News
April 29th, 2013 9:18 AM
firelance911
November 15th, 2010 9:35 PM
