Ring and Pinion
Confirmed by dealer and what I suspected, ring and pinion bearing making a bad noise on 2000 Silverdo with 85,000 miles on it. Anyone else had a problem with this. Dealer says $1500 to fix, of course extended warranty has ran out.
I'm not sure if it's the same rear end, but we recently replaced the pinion bearing, race and pinion seal on our '96 silverado and it cost only 180 dollars. It sounds like you need to find another mechanic
I would find new mechanic if it's a bearing they can be replaced. GM does not use delco moriane bearings anymore they can have 2 or 3 diffirant brands in the same unit. I have seen lots of bad side &pinion bearings.
As long as you're reusing the stock gears, just replace the bearings yourself. Pull the wheels off and if you have drum brakes take the drum off and push the axle in. Pull off the rear diff cover and then take out the c-clip out of the carrier and then you can pull the axle out. Once the axles are out, mark the caps to so you can put them back where they came from. Unbolt them and then pull the ring gear and carrier out and then take it to a machine shop to get the old bearings pressed out and put new ones in. If you're going to replace the pinion bearings, use a pipe wrench to hold the pinion and then losen the nut and pull out the pinion gear. You'll have to use a brass floating punch to remove the old bearing races from the housing. Then again take the pinion to a machine shop to swap out the bearings using the same amount of shims that came out.
Chevygirl4x4
January 17th, 2014 6:30 AM
Ole' Blue95
December 27th, 2009 1:52 AM
