Rough shift from 1st to 2nd?
Old May 11, 2010 | 6:47 AM
BBrock293's Avatar
Default Rough shift from 1st to 2nd?
I have a 2006 Silverado 5.3 Crew Cab with 39K miles. When I am accelerating at a normal rate, I am getting what seems like a slight delay going from 1st to 2nd, then when it shifts sometimes it clunks and it is a rough shift with a small jerk. I do not have this problem with any of the other gears, it is a very smooth shift. If I get on it, the it is delayed even further then the shift is real rough. Any thoughts?
Old May 11, 2010 | 8:19 PM
desrtrat's Avatar
sounds like the shift solenoid is going bad. had a like issue with my trans when the truck was new. dealer replaced, and all good..
good luck
Old May 11, 2010 | 9:45 PM
pickupman's Avatar
same thing happened to my 97 half ton. try the solenoid first. it's a pretty common problem from what i've heard. my problem ended up being the torque converter though
Old Jun 1, 2010 | 7:37 PM
Mille Racer 69's Avatar
are you the original owner?
If it shifts hard like that,
the truck may have a quick-shift kit like mine.
it just helps it go to the next gear and get up to speed faster or whatever.
Rodknock
Jun 25, 2015 2:09 PM
BWS
Nov 12, 2010 2:39 PM
BigFish246
Astro
Jul 19, 2009 7:14 AM
HeavyChevy883
Mar 15, 2008 9:29 AM
