Royal Purple
#11
Ok I just called O'Reillys and they are going to hold 15 Quarts of RP Oil and 3 K&N Oil Filters. 2 Bottles of RP Transmission fluid. And they have 75W and 90W RP Gear oil. Do I need to replace Transmission Filter?
#12
damn im not sure which one i used lol. its best to change the filter its like changing an oil filter. you change that every time you change the oil right? lol. there is an o ring inside where the filter is and its a bitch to get out. also i had to undo my exhaust from the y pipe because the shift linkage bracket is in the way and there are two torx bolts on top and can only get to them by feel. i gave up cuz i think i stripped one so thats when i undid my exhaust. lol.
#13
Damn....Ok well I am going to change out all the fluids this weekend along with my power steering again (just did it Sunday Night). I will let ya know if I ran into the same problems.
#14
sounds good. gonna be a full day of changing fluids lol. easiest change will be your rear diff haha. when you change that.. get a small can of "the right stuff" its a silicone gasket maker, diy gasket so to speak, just put it on your diff cover and pray you can find your bolt holes lol.
#18
This is not true at all. If you do not believe me call Mobil 1 or any other company. Now if you put in a high mileage oil it has a seal sweller in it, so once you put a high mileage oil in you can never go back.
#19
Makes sense. I've heard the Conventional to Synthetic, never go back a few times. So I've always went by that. But from my tiny bit of expierience. I'm gonna think like what MDtahoe said.
