scraping noise rear of silverado
Old Sep 23, 2014 | 4:54 PM
chevyman2014's Avatar
Default scraping noise rear of silverado
Hello,
I have a 2005 silverado 1500. I have a scraping noise from the rear of the vehicle, (metal to metal) sound. I have taken the rear wheels off, placed in neutral and rotated the tires. There is not a metal to metal sound there. I have not taken apart the brake drum.
I also noticed when i manually moved the wheels(rear) that the prop shaft made a somewhat whinish sound(not high pitched or metal to metal).
Would that be normal for the prop shaft to do that. I have checked the u joints and they are tight.
would anyone have had any issues with this type of problem.
Thanks for any help
D.
Old Sep 23, 2014 | 7:46 PM
89scottsdale's Avatar
People on here are pretty worthless when it comes to answering. assuming your truck is not lifted or running bigger tires, this sounds like a Brake issue or maybe a bad rear end. id check to see if a caliper is hanging up, your pads are worn, or a rotor is bent. if not, some sort of clutch in the rear end could be gone and getting in the gears, but the whine you describe concerns me. take your rear end plate off and have a look. if it smells burnt, find the issue and correct it. if the oil is clean and no shavings are found, replace your oil. i am not familiar with chevy rear ends, but very familiar with dodge rear ends since my old one ate itself due to a differential slip clutch exploding.
Old Sep 23, 2014 | 7:49 PM
Oh.. and also, see if the grinding goes away when you change between four high and 2 wheel drive while driving.
dureezy
Sep 13, 2014 5:33 PM
thejumpsuitman
Sep 21, 2010 10:30 PM
RMWcavalier
Apr 5, 2010 4:42 AM
avoyager
Apr 21, 2008 9:11 PM
jessegranat
Sonic (Aveo)
Jan 17, 2007 5:48 PM
