sensors
Old Dec 16, 2010 | 6:19 PM
wn7186's Avatar
Default sensors
can somebody tell me what sensor is directly beneath the distributor on a 1998 k1500 350. And if its not a sensor what is it
Old Dec 16, 2010 | 7:55 PM
6LCHEVYZ71's Avatar
pic would help. I would go look under my hood for ya but I have an 87 and a 99...
Old Dec 16, 2010 | 8:48 PM
OLD WRENCH's Avatar
If its at the back of the dist you are probably looking at the oil press sensor.
Old Dec 16, 2010 | 9:23 PM
wn7186's Avatar
reason im asking is im having a clicking noise immediately followed by a skip in the engine coming from this area. have ruled out distributer and wire and plugs due to the fact that it only does this once the engine is warm. also engine skips severly like fouled plugs or bad wires when driving and then goes right back to running great all along making this clicking as the motor skips
Old Dec 16, 2010 | 9:58 PM
6LCHEVYZ71's Avatar
sure it's not the cap & rotor?
Old Dec 17, 2010 | 3:22 PM
DoubleO7's Avatar
On my 99 the oil pressure switch (one of them) is to the right of the dist. when looking at the front of engine.
Then the firewall is behind the dist.
Old Dec 17, 2010 | 7:05 PM
6LCHEVYZ71's Avatar
A pic would help
Old Dec 17, 2010 | 9:35 PM
wn7186's Avatar
i can hardly see it myself much less get a picture of it. whatever is causing this missfire just suddenly stopped this after. I have made a couple of trips and it is running as smooth as can be. very odd just dont know i mean obviously a sensor is going bad due to the fact that it only happens at operating temp unless my computer has a glitch which i guess could be and no codes just a missfired cylinder which is obvious
Old Dec 17, 2010 | 10:28 PM
OLD WRENCH's Avatar
If all else fails pull the dist. and check the gear on the bottom, sometime they go bad.
swatson1
Feb 26, 2017 8:25 PM
RedBoat
Dec 20, 2007 10:52 PM
tahoe07
Dec 11, 2006 8:16 PM
av8rkirk
Nov 1, 2006 1:08 AM
smalltuck
Jan 24, 2006 11:32 AM
