Service 4WD Message??
Old Dec 9, 2015 | 1:50 PM
nbarr7655's Avatar
Default Service 4WD Message??
Hey guys. Pulling into work this morning I looked down at my dash and noticed "Service 4wd" and none of my lights are lit up for my push button 4x4. I did some searching and found a bunch of different answers or problems it could be and was hoping to get some solid answers from you guys.
It's a 2004 Silverado 1500 ext cab and it just hit 153,000. I hardly use the 4x4 but then again have only had the truck about a month and a half. I used the 4wd just fine about 2 weeks ago though when we got some snow. When this happened I can't push the 4wd buttons. Well techincally I can, but nothing happens.
There was no noises or anything when this message came up. Is it a sensor or something simple? Thanks!
Edit: I shut the truck off and started it again with no fix. About an hour later I went out and started it to leave and all is fine again. So what's the deal?
Old Dec 9, 2015 | 8:40 PM
cleveland63b's Avatar
to be safe check the fluid level and condition, otherwise you'll need to get codes checked to see which direction to go
