Severe Bog Issue with 93 Chevy silverado
Hi coreyawood,
Did you figured it out the issue was the EGR, New EGR solenoid and fuel filter.by the comments from this post/forum or something else. I saw the 02 sensor corrected from T AKA Tweekin issue in his last comment. I have a 93 GMC P35 with pretty much the same problems below as Tweekin , I had the gas smell, but think one of many trial and errors took care of that I think.
. bog is at it's worse when the RPMs are between 1200 - 2200. Sometimes when the traffic lights turn green when sitting there,
. I will give it gas and seems that there was a blip of power then gone and comes back which results in me slamming my head into my steering wheel haha (Truck doesn't shut off). When I'm in overdrive, I can hardly make it up a small hill, sometimes same case scenario in 3rd gear. When in 3rd or overdrive, the truck would shake bad.
. There are times where it works perfect for a while though.
NEW PARTS
Had the truck scanned. Nothing showed up.- yes
Put in a new Throttle Positioning Sensor.- ????
Fuel Pump Relay - ????
Fuel Filter - no
EGR Valve - no
EGR Solenoid - no
A Couple of New Hoses
Spark Plugs - ????, I think
Spark Plug Wires -yes with in a year or so
Cap - yes , yes with in a year or so
timing ????
Rotor Coil -???
MAP Sensor - yes
TEMP sensor -yes
fuel pump pressure regulator- yes
Idle control Valve - yes
02 sensor
Full Distributor -???
Fuel Pressure Regulator (probably wrong name for it) - yes
New Computer PLUS new Prom for it.- No
Complete Exhaust System (Header pipe to tail pipe)
Fuel Injectors - No, Spray good tech says
etc.
etc.
Thanks,
NEW PARTS
Fuel Filter - no
EGR Valve - no
EGR Solenoid - no
timing ????
Rotor Coil -???
MAP Sensor - yes
TEMP sensor -yes
02 sensor
etc.
etc.
Thanks,
