Silverado 1500 Window Motor?
Passenger side window is going up pretty slow compared to my driver window, and it squeels as it goes up but I know thats from the sliders on the inside of the door panel. Does it need just a new window motor or something else?
Apply the silicon spray on guides or lubricate all the moving parts. This would act fine for two-three months, but for permanent solution, you have to change 2005 Chevrolet Silverado 1500 Window Motor.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> mshaw130,
The anti-noise sleeves can cause a squeak noise too, in addition to the cable/pulley assembly, rail and/or motor and gearbox housing. This is just a suggestion, not a diagnosis. As for the slow speed, it may be time for a new motor. I encourage you to consult with a certified technician for an inspection and more accurate diagnosis.
Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
Boy oh boy just took mine a part 100% cleaned contacts in motor greased everything I would not recommend taking motor apart its kinda hard to reassemble
anyway up faster but not 100% but will work till it dies was hoping
gbrown70
November 8th, 2011 1:35 AM
davbell22602
March 10th, 2010 8:36 PM
kardan
October 2nd, 2009 9:59 PM
