Silverado 1500 Window Motor?
Old May 20, 2012 | 11:12 PM
mshaw130's Avatar
Default Silverado 1500 Window Motor?
Passenger side window is going up pretty slow compared to my driver window, and it squeels as it goes up but I know thats from the sliders on the inside of the door panel. Does it need just a new window motor or something else?
Old May 21, 2012 | 5:03 AM
I would change the assembly. Hate to do all that work to just have to do it again in a while. The track and cables wear and eventually fail.
Old May 21, 2012 | 9:23 AM
johntaps's Avatar
Former Sponsor
Post Silverado 1500 Window Motor?
Apply the silicon spray on guides or lubricate all the moving parts. This would act fine for two-three months, but for permanent solution, you have to change 2005 Chevrolet Silverado 1500 Window Motor.
Old May 21, 2012 | 11:07 AM
RacerX's Avatar
silicon paste works better than spray if you can get that. if not, white lithium paste will work also, if not the bearing grease may work.
Old May 21, 2012 | 1:40 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> mshaw130,
The anti-noise sleeves can cause a squeak noise too, in addition to the cable/pulley assembly, rail and/or motor and gearbox housing. This is just a suggestion, not a diagnosis. As for the slow speed, it may be time for a new motor. I encourage you to consult with a certified technician for an inspection and more accurate diagnosis.
Please keep us posted.
Louis
GM Customer Service
Old May 21, 2012 | 8:17 PM
Doug Roberts's Avatar
Boy oh boy just took mine a part 100% cleaned contacts in motor greased everything I would not recommend taking motor apart its kinda hard to reassemble
anyway up faster but not 100% but will work till it dies was hoping
cubangt
May 12, 2022 7:41 AM
justin69
Feb 28, 2015 2:54 PM
gbrown70
Nov 8, 2011 1:35 AM
davbell22602
Mar 10, 2010 8:36 PM
kardan
Oct 2, 2009 9:59 PM
