Silverado 20" wheels
Just hit em with an impact while off the ground, lower it to where the tires are barely touchin, enough not to move when you put a break over bar on it. I don't know the settings but I do this everytime and have yet to have a problem
since your in the rust belt apply a rust preventative around the hub snout that protrudes throught the rotor and also to the rotor mounting surface and rim mounting surface.
That way when your rotate your tires they come off easy and you won't have to clean corrosion build up off the rotors or rim mounting surfaces.
I was hoping for a "real" answer not some hope for the best joke retort.
Most tire shops who are worth their salt will use a "Torque Wrench" for the final setting of the lug nut.
henson50
May 19, 2014 8:02 PM
gunrnr
Aug 31, 2010 9:18 PM
For Sale: IROC 20"22"24"26" W.TIRE pkg
chevyman323
Jul 16, 2010 11:56 AM
oldvet58
Mar 6, 2010 9:13 PM
