silverado 5 speed stuck in first
alright well i was coming off a light and shifted to second let out on the clutch and i was still in first. theres almost no tention between first and second and i cant even get the shifter to move over to third fourth...
i took off the shifter boot and all and had a look down in the tranny the rod moves fine but it doesnt move the forks at all. idk. what should i do?
throwout bearing could be stuck open. or slave cylinder isnt gettin pressure....air pocket in the master cylinder. i just put a clutch in my truck the other day and had to replaced my slave cylinder because it wouldnt go into gear. turns out i had an air pocket in te master cylinder
nope just cross member. dropped trani and transfer case all at once. bell housing got caught up on my exhaust but nothin some jack work and pry bar didnt fix
