smoke or steam coming from tailpipes after engine is turned off
#11
It runs fine knocks pretty good at first crank in the morning I think it is from the valves in the head it has over 200,000 miles on it I was thinking about a new crate motor for it or just new heads not sure yet
#12
Mine, under load the motor starts knocking and increases with throttle, like in 3rd or 4th gear when trying to accelerate without downshifting or when i'm pulling a trailer. Found out today that mine is an oil burn, popped heads off to check the valves and about 5 of them you can wiggle around, valve guides are worn beyond limit
#14
if they are factory heads then there are no adjustments. would either need to get heads rebuilt or buy new. i would personally just buy new. is more of a tick or is it a knock? because if it's a loud ticking on first start up than it's just the lifters making noise until the get oil
MMullen614
February 3rd, 2018 3:57 PM
Syncman
May 3rd, 2015 1:03 PM
GP1969
Avalanche
April 18th, 2013 5:31 PM
