Spark Plug Change - Aluminum Heads
I'm getting ready to change the plugs in my '04 Silverado with a 5.3 eng. What is the best anti-seize to use on the threads as this eng. has aluminum heads? What have you used that works well, or what is NOT recommended? Thanks.
edit.. also pick up a small tube of dielectric grease and put a small amount in the plug boots, and roll the boots between your fingers to spread it evenly in the boot, and install..will help a lot when you have to remove the wires again.. ALSO put on your coil boots also..
good luck
sngreen
June 4th, 2007 7:48 AM
girraffe111
April 27th, 2005 10:17 PM
